carol@chiang
[ERROR] : Error reading hex characters from file - top.hdf when generating BOOT.bin
I was generating BOOT.bin but failed with the following error message. Any solution?
Thank you
cmd /C bootgen -image output.bif -arch zynqmp -o \
C:\Users\lidar-demo\Documents\gen_image\rf\BOOT.bin
****** Xilinx Bootgen v2018.3
**** Build date : Dec 7 2018-00:33:34
** Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
[WARNING]: [fsbl_config] a53_x64 | a53_x32 | r5_single | r5_dual will be deprecated, please use 'destination_cpu' attribute of bootloader partition
carol@chiang
Hi all,
Sorry I found I include HDF file in UDF DATA.
[udf_bh]C:\Documents\boot\top.hdf
Really a big mistake...
Sorry and thank you for your help
ibaie
Hi carol@chiang
Could you share your BIF file content?
Ibai
carol@chiang
Hi ibaie,
Sorry for the delay.
//arch = zynqmp; split = false; format = BIN
the_ROM_image:
	[fsbl_config]a53_x64
	[bootloader]C:\Documents\boot\fsbl.elf
	[pmufw_image]C:\Documents\boot\pmufw.elf
	[destination_cpu = a53-0, exception_level = el-3]C:\Documents\boot\bl31.elf
	[destination_cpu = a53-0]C:\Documents\boot\u-boot.elf
	[destination_device = pl]C:\Documents\boot\top.bit
	[destination_cpu = a53-0]C:\Documents\boot\Image
Any suggestion is welcome.
Thank you
carol@chiang
Hi all,
