xjzju
ERROR: fpga(zynq) initialization failed
Hello,I design a ZYNQ board using XC7Z100.When I just use vivado progama the PL part,it success.But,when I use the PS part,export the hardware,and launch SDK,But when I use the SDK download fpga(ZYNQ),it hint fpga initialization failed.
How can I solve it,thank you!
gudishak
Hi @xjzju,
Have you tried with latest SDK?
Kranthi
Best Regards
Kranthi
