ERROR: unable to find numeric literal operator 'operator""U' ???
Hi guys,
I am working with Zynq and Vivado 2017.4. I had the same code working without any problem, but now it is throwing this error after changing some connections in the block design. I have undone the changes but it still complains.
../../MicroZed_design9_bsp/ps7_cortexa9_0/include/xparameters.h:557:40: error: unable to find numeric literal operator 'operator""U'
 #define XPAR_AXI_TIMER_0_CLOCK_FREQ_HZ 1e+08U
Where is this coming from?
Cerilet
Re: ERROR: unable to find numeric literal operator 'operator""U' ???
Ok, I have found a temporary solution. I do not know how it happened because is Vivado who generated this line, which is linked to the AXI clock (100MHz).
I have removed the exponent and now it compiles.
#define XPAR_AXI_TIMER_0_CLOCK_FREQ_HZ 100000000U
However, I have no clue why the code compiled before. I have not changed the AXI clock from the previous version to this one.
So it is indeed a temporary solution because next time I made any changes in the block design, it will re-generate the xparameters.h file and I will have to modify this line again.
Does anyone have an idea where this is coming from?
This is generated by axi_timer driver, based on the HW design.
$XILINX_SDK/data/embeddedsw/XilinxProcessorIPLib/drivers/tmrctr_v4_4/data/tmrctr.tcl
Can you run the commands listed below in XSCT to see what value you get for CLK_FREQ
1. openhw <path/to/hdf>
2. hsi report_property [lindex [hsi get_pins S_AXI_ACLK [hsi get_cells axi_timer_0]] 0]
Hi @sadanan,
I just saw in the Vivado Tcl console these warnings:
WARNING: [IP_Flow 19-3452] Invalid long/float value '1e+08' specified for parameter 'FREQ_HZ(CLK)' for design_9_auto_pc_0.
WARNING: [IP_Flow 19-4684] Expected long value for param s_axi_lite.FREQ_HZ but, float/scientific notation value 1e+08 is provided. The value is converted to long type(100000000)
And about the commands in the XSCT console, here is the output:
Property      Type    Read-only  Value
CLASS         string  true       port
CLK_FREQ      string  true       1e+08
DIRECTION     string  true       I
INTERFACE     bool    true       0
IRQID         string  true
IS_CONNECTED  bool    true       1
LEFT          string  true
NAME          string  true       s_axi_aclk
RIGHT         string  true
SENSITIVITY   enum    true
TYPE          enum    true       clk
There is still the 1e+08, which is causing the problem.
I'm not too familiar with Vivado side of things. I guess export2sdk has put the float value into the HDF (that's where XSCT/driver tcl read the frequency). I'm trying to find more details
Hi @cerilet,
export2sdx seems to be picking the frequency from IP XCI file. Can you please check what value you have in the IP configuration wizard and the XCI file?
In the IP configuration wizard I have 100 (MHz).
Then, in the XCI file I have found this:
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.FCLK_CLK0.FREQ_HZ">1e+08</spirit:configurableElementValue>
So it seems the error comes from here. But why it did not throw an error earlier and now it does? Very weird.
Well, I continued working by changing this line on the xparameters.h file every time I modified the block design:
by this one:
However, I had to do a major change on the design and I decided to create a new block design from the old one copying all blocks from one design to the new one, and after generating the bitstream and exporing to vivado it does not appears anymore the 1e+8U.
Just letting guys from Xilinx know so they might find where this was coming from.
Cheers,
Cerilet
Scholar vanmierlo
I'm experiencing a similar problem. I also see Vivado generating such warnings and then my device-tree build fails due this 1e+08 value. I'm using Vivado 2017.4 and this just started to happen. Since I did not install anything new in/of Vivado could it come from an OS update? I'm using Ubuntu 16.04.
Maarten
Hi @vanmierlo,
I have no clue where this is coming from. I made some modifications of the block design, and after resynthesizing and generating another bitstream, the error disappeared.
Then, I did some other modifications which in my opinion do not have anything directly related to this, and the error appeared again.
Very weird. If I ever find out, I will post it here.
Cerilet
Scholar vanmierlo
I had the same experience. It went as easy as it came. I just hope it doesn't resurface any time soon.
Visitor alexachey
I'm having a very similar problem as well.   I had a design that was working properly with Vivado 2017.4.1 under Windows 7 and the SDK/Petalinux in a VM.   I then created and inserted a new IP package with an AXI-Lite + and AXIStream interface into the diagram and tried building with just the created "template".   After that I started getting warnings like the below:
WARNING: [IP_Flow 19-3452] Invalid long/float value '1e+08' specified for parameter 'FREQ_HZ(CLK)' for Z_design_auto_pc_0.
WARNING: [IP_Flow 19-4684] Expected long value for param ACLK.FREQ_HZ but, float/scientific notation value 1e+08 is provided. The value is converted to long type(100000000)
I can ignore the warnings, but the device tree build fails when it gets to my axi_uart16550 with
FATAL ERROR: Unable to parse input tree
If I look at the line it fails on, it's the frequency:
axi_uart16550_2: serial@43c00000 {
  clock-frequency = <1e+08>;     <--fails here
  clock-names = "ref_clk";
In my case there's no "U" causing trouble though.
Removing the IP from the block diagram doesn't fix things.
Try changing the 1e+08 by 100000000. It worked for me.
Cheers.
Cerilet
Scholar vanmierlo
Manually? Every time you rebuild your petalinux? That's not a comfortable way to work.
Well, it happened to me from time to time. But yes, I couldn't find the source of the error so I did it manually. That's something the guys from @xilinx should find and repair.
Try to generate again the whole Bitstream. As I said, this error appears only from time to time.
Good luck.
Cerilet
All of a sudden I started getting this error also for  2018.1. It's a pain to have to fixed it manually all the  time.
