Error using EDK 9.2 reference design in EDK 11.1
I am currently using EDK 11.1 with a Spartan 3E starter board. The reference designs provided for this board are all for EDK 9.2. When I try to open these designs in 11.1, it tries to upgrade the project but gives a lot of errors like :
ERROR:EDK:467 - E:\spartan3-e\sp3e1600e_mb_bclinux\system.mss line 5 - Can not find MLD for the os standalone 1.00.a
ERROR:EDK:1552 - IPNAME:xps_mch_emc INSTANCE: FLASH - E:\spartan3-e\sp3e1600e_mb_bclinux\system.mhs line 231 - cannot find MPD for the pcore
Please let me know a way to work around this
Thanks and Regards
Tushar Janefalkar
htsvn
Either you can replace line 5 in MSS with version 2.00a
like this
BEGIN OS
PARAMETER OS_NAME = standalone
PARAMETER OS_VER = 2.00.a
And the line 231 of MHS with the version number matching to the xps_mch_emc core version numbers available in the folder
$EDK_Install\hw\XilinxProcessorIPLib\pcores
 (Or)
You can create a new BSB project using the same components as in the MHS.
Thanx.
anee_anil
I do have the same problem. I have spartan 3 mini module. The reference design given are using OPB, in EDK11.1 I could not able to find OPB. By default it is taking PLB.
The reference design given are using EDK 7.1 How to suceesfully upgrade to EDK 11.1.
Please Help me.
with regards
htsvn
OPB is deprecated starting from EDK_92. So  please create a BSB design using EDK 11.1.
This is because you have not set the option of seeing the deprecated cores.
You can set this up by going into Edit ==> Preferences ==> IP Catalog and Config. Therein you have the options to set the deprecated cores as well. Check all the options in that tab and you should see all the cores.
Check this too
http://forums.xilinx.com/xlnx/board/crawl_message?board.id=EDK&message.id=1081
anee_anil
Hi hem,
When I try to upgrad, Some of the IP cores are not found. those are all have new version.
EDK gives following errors after upgradation
can notfind MDD for not upgraded drivers. I have attached the screen shot of not upgraded IP cores.
Please find the attachment.
with regards
