Anonymous
Not applicable
Fatal ERROR while using GENERICS for comparing
I have an entity with the following generics
LOWER_BOUND : integer := 1350;
UPPER_BOUND : integer := 1400;
in my architecture i use this to check if a register is in some predefined bounds
signal chk_reg : unsigned(13 downto 0);
valid <= '1' when (chk_reg >= to_unsigned(LOWER_BOUND, 14) ) and (chk_reg <= to_unsigned(UPPER_BOUND,14)) else '0';
i tested this code as a stand alone design in ISE on an virtex2p and it worked fine. Also simulation didn't show any problems.
But as soon as I used it in a bigger design with EDK it gave me the FATAL ERROR.
Is this a bug in EDK? I'm using 10.1 SP3
Sebastian
Historian
Historian
Sebastian
It might help if you gave us the exact error message.
-a
