GCC runtime problem switch case variable declaration
I use the GCC 4.1.1 on ppc405. (gcc version 4.1.1 20060524 (Xilinx EDK 10.1.03 Build EDK_K_SP2.5 11 Jun 2008))
In a switch statment I use the following snippet
unsigned int value;
case SENSOR_DUALSLOPE_TIME:
float time = 2.0f;
value = *((uint32_t *)(&time));
break;
If  I compile my code with optimization -O1 the contents of value is right.
If  I compile my code with optimization -O2 or -O3 the contents of value is incorrect.
But if I use the following snippet:
float time = 2.0f;
printf("%f", time);
break;
all is right.
Does anyone knows the how to fix it or reason why? I need to keep the optimization -O2 or -O3.
Thanks, Thomas
I suspect this is an issue in your code due to gcc's strict aliasing options kicking in at -O2. Read about the -fstrict-aliasing option in gcc manual:
http://gcc.gnu.org/onlinedocs/gcc-4.0.2/gcc/Optimize-Options.html
You can explicitly disable it (-fno-strict-aliasing), but that is not a good practice.
thanks for the answer. Yes, so it is.
An explanation I found here:
http://www.cellperformance.com/mike_acton/2006/06/understanding_strict_aliasing.html
