pedro_uno
Advisor
Advisor
HDF Mangagement for Stand-Alone SDK Programming
Hello Guys,
I am doing a little stand-alone programming on a MicroBlaze processor.
I have written some C code that interacts with some AXI peripherals. The original SDK project was exported from Vivado and has the addresses and bare metal drivers in the bsp. That is very convenient.
Now I have added another AXI peripheral to the design and I would like the bsp to know about it. My fpga compile script generates a new .hdf file with the additional peripheral.
How should I bring the new .hdf file into my old SDK project?
I have tried just copying the new one over the old one but SDK will not compile after that.  I have searched around for some kind of import feature but not found that either.  I have searched for Xilinx documentaion that might advise on how to handle hardware modifications in SDK but not found anything on point.
Any advice is greatly appreciated.
  Pete
DSP in hardware and software
sampatd
@pedro_uno
SDK is capable of monitoring HW changes and re-generate the BSP
For more details, please check the link below:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/SDK_Doc/SDK_tasks/sdk_t_auto_sync.html
pedro_uno
Advisor
Advisor
I think I remember running SDK in a mode where, at startup, it would see changes to the HDF and ask me if I wanted to incorporate them.
eurecam2005
In your workspace, you should have a directory which contains an hdf file (for example "your_design_hw_plateform_0")
You could manually replace the hdf file ("your_design.hdf") by a new one (exported from vivado).
Then try to regenerate BSPs,  hardware modifications (new ips, parameter or address changes, and so) should be visible in the updated BSPs. If not, a workaround is to create new BSPs.
If you created new BSPs, associate you projects with the new BSPs then you could delete the old BSPs.
sampatd
@pedro_uno
pedro_uno
Advisor
Advisor
Thanks, I never would have found it without that tip.
