Hi, When ever I run a project, my XPS EDK generates follo...
When ever I run a project, my XPS EDK generates following error. Also when I run a downloaded example, the same error prompts. I am using EDK ver. 8.2i (Evaluation):
At Local date and time: Tue Nov 06 17:02:12 2007
 xbash -q -c "cd /cygdrive/d/Aftab's Files/EDK_Projects/Start_with_LCD/; /usr/bin/make -f Start_with_LCD.make bits; exit;" started...
/usr/bin/bash: -c: line 1: unexpected EOF while looking for matching `''
/usr/bin/bash: -c: line 2: syntax error: unexpected end of file
Done!
Please help me.
It's also looks like you have " " in your path. That is not allowed and will cause various error messages.
Göran Bilski
What happens when I run an example, every thing should be allright. Please try to explain further
