How to Use customer IP in both ZYNQ7010 and 7045 in vivado.
HI:
 How can I use customer IP in both ZYNQ7010 and 7045 in vivado?
 The package IP wizard points to select a ZYNQ part in the IP setting window,in which I select xc7010225.
 and I set the compatibility to ZYNQ family.
But I still can not find the customer IP in the project ZYNQ7045.
What should I do to access my customer IP in both 7010 and 7045 projects?
Thanks very much!
Re: How to Use customer IP in both ZYNQ7010 and 7045 in vivado.
Sorry , I made a mistake.I select a QZYNQ part with my ZYNQ IP. They are compitiable in default.Thanks!
Scholar stephenm
is the IP you created added to the repository in Vivado?
Yes ,of course. I have added the directory in the Repository Manager.But I still can not find it in the IP Catalog.Did I miss anything ?  Thanks!
