d4223738
How to build platform files for the C++ application in the SDK?
Since the C++ application project in the SDK does not have any example template.
How should we build platform files for the C++ application project?
Can we transfer from a C application project?
Best wishes,
Lei
hbucher
@d4223738
I usually create a hello world in C and then copy (drag/drop) those files to a new C++ application.
hbucher
@d4223738
pvempati
We have a example project for C++ application also in SDK, but this application works only for Linux OS. You can take the reference of this application if you want. Please check the attached screenshot to select the c++ example project in SDK.
Thanks & Regards,
Praveen Kumar. V
