caleb2954
How to debug a C program using SDK on xilinx?
I'm using an Atlys spartan 6 xc6slx45,I have to debug this code :
1-#include "stdio.h"
2-int main (void)
3-{
4-// Initialization of the necessary variables
5-int i,j,k;
6-// Initialization of source A and B 4x4 matrices and result C matrix
7-int a[4][4]={ {1,2,3,4},
8-{1,2,3,4},
9-{1,2,3,4},
10-{1,2,3,4}};
11-int b[8][8]={ {1,2,3,4},
12-{1,2,3,4},
13-{1,2,3,4},
14-{1,2,3,4}};
15-int c[8][8]={ {0,0,0,0},
16-{0,0,0,0},
17-{0,0,0,0},
18-{0,0,0,0}};
19-xil_printf("‐‐ Entering main() ‐‐\r\n");
20-for (i=0; i<4; i++ )
21-{
22-for (j=0; j<4; j++)
23-{
24-for(k=0; k<4; k++)
25-{
26-c[i][j]=c[i][j]+a[i][k]*b[k][j];
27-}
28-}
29-}
30-for (i=0; i<4; i++ )
31-{
32-for (j=0; j<4; j++)
33-{
34-xil_printf("%d ",c[i][j]);
35-} dgcustomerfirst
36-xil_printf("\n\r");
37-}
38-return 0;
39-}
I add a toggle to the 5,7,11,15,26. I went to Run-->Debug Configurations --> Xilinx C/C++ application(GDB) ---> Build configurations:Debug then I pressed Debug button. I got this error :
No source available for "_start()".
Target failed:Target is not responding(timeout).
savula
Hi @caleb2954 ,
To Debug the applicaiton from SDK, you need to connect the board first. I hope you are not connected to any board and try to debug the applicaiton directly and the tool is giving the error. Please connect the board then debug the application.
Best Regards,
Srikanth
