Andres2460
How to do a simple aplication with usb and wifi on a avnet ultra96 ?
Hi there. I'm currently trying to do a simple application that have to do with transfer some data from usb to my pc via wifi making use of a board avnet ultra96. Do you have any idea of how can I do this ?
I appreciate a lot your help. Thanks in advance.
bhfletcher
There is a USB connection on the High-speed mezzanine. Unfortunately, no one in the 96Boards community has created a USB-to-WiFi mezzanine because the 96Boards standard requires WiFi on the baseboard.
I think your only option is either design your own High-speed Mezzanine with USB-to-WiFi, or use a simple adapter like you can find on Newark or Farnell. I've never done that, so no promises on driver compatibility, but we've had good luck so far with all the other USB things that we've tried.
https://www.newark.com/lm-technologies/lm005/wifi-usb-adapter-300mbps-802-11n/dp/15R1831
https://uk.farnell.com/lm-technologies/lm005/wifi-usb-adaptor-300mbps-802-11n/dp/1716034
Bryan
