wtneo@leica
How to map true and false values in xparameters.h to integer
  I have created my own IP with GUI to let user turn on/off some features.
  In IP Packager, these settings are set as Boolean to let user tick or untick in block diagram.
 Because of this, these parameters are exported like below in xparameters.h:
    #define  XPAR_MYIP_0_IS_MONOCHROME   true
  Problem:  I need to map this to integer 1 or 0 but  not sure how.  Anyone can help?
regards,
Neo
stephenm
The xparameter.h file is populated using the TCL files in the data folder for each driver. For example, taking the AXI GPIO as reference as it is simple:
2018.1\data\embeddedsw\XilinxProcessorIPLib\drivers\gpio_v4_3\data\gpio.tcl
There is a generate proc that will be run:
proc generate {drv_handle} {
::hsi::utils::define_include_file $drv_handle "xparameters.h" "XGpio" "NUM_INSTANCES" "C_BASEADDR" "C_HIGHADDR" "DEVICE_ID" "C_INTERRUPT_PRESENT" "C_IS_DUAL"
::hsi::utils::define_config_file $drv_handle "xgpio_g.c" "XGpio" "DEVICE_ID" "C_BASEADDR" "C_INTERRUPT_PRESENT" "C_IS_DUAL"
::hsi::utils::define_canonical_xpars $drv_handle "xparameters.h" "Gpio" "C_BASEADDR" "C_HIGHADDR" "DEVICE_ID" "C_INTERRUPT_PRESENT" "C_IS_DUAL"
So, this will add the params for Num_instances, base_address, ect.. Im assuming your driver looks similar. So, what you can do is, remove the parameter from the list here, and create a custom proc to add the info you want. for example:
proc add_params {drv_handle file_name}
    set ip_name [string toupper $drv_handle]
    #note: I made a guess at the param name here.
    set param_name [get_property IS_MONOCHROME [get_cells  $drv_handle]]
    if {$param_name != ""} {
        set file_handle [::hsi::utils::open_include_file $file_name]
        if {$param_name == "true"} {
              puts $file_handle "\#define XPAR_${ip_name}_IS_MONOCHROME 1"
        } else {
              puts $file_handle "\#define XPAR_${ip_name}_IS_MONOCHROME 0"
        close $file_handle
Then update the generate proc to call this new proc:
add_params $drv_handle "xparameters.h"
smcnutt
Hi Neo,
stdbool.h has what you desire. For details see The Open Group Base Specification for example.
--Scott
Edit: Fix link to Open Group stdbool.h page.
stephenm
        } else {
        close $file_handle
wtneo@leica
Tks all,
  I did not want to add boolean type to my driver for one time use only, so I did not use stdbool.h
  I found this solution elsewhere, so I added this to the driver file :
#define true 1
#define false 0
  So it works for me now.
Neo
