Visitor liao7wei
How to program the .bin file into the parallel flash on ML507 borad by using the XPS?
hello everyone ,
I do a work on the ML507 board .I use xilinx ise 12.4. I want to program  the .bin file into the parallel flash by using the XPS. I don't find the right way to do it . I  have nothing but the .bin file provided by institute.
I open the XPS, and choose “Program Flash Memory” from the menu. It doesn't  work.
I really need help.
best regard
Re: How to program the .bin file into the parallel flash on ML507 borad by using the XPS?
hi,
since you are using ml507, would that be possible to use one of the existing reference systems to check if the board is fine
http://www.xilinx.com/products/boards/ml507/ml507_11.1_1/standalone_apps.htm
--hem
Scholar pratham
Check this XAPP. This might help
http://www.xilinx.com/support/documentation/application_notes/xapp1106.pdf
-Pratham
Refer to page 26 of  http://www.xilinx.com/support/documentation/boards_and_kits/ug348.pdf  to program  the .bin file into the flash by using the XPS.
Praveen
hi,
if you would want to start creating your own .bin files, you can refer to the example designs available here.
http://www.xilinx.com/products/boards/ml507/ml507_12.1/standalone_apps_ppc440.htm
--hem
Visitor liao7wei
Dear Pratham,
       When I open the system.xmp file in XPS, and go to the "Device Configuration"/"Program Flash Memory" menu and proceed, it causes the error.
Conversion to XML complete.
Executing xmd script : D:/Xilinx/12.4/ISE_DS/EDK/data/xmd/flashwriter.tcl
Flashwriter starting...
Sourcing etc/flash_params.tcl...
* Connecting to target...
JTAG chain configuration
Device ID Code IR Length Part Name
1 d5059093 16 XCF32P
2 d5059093 16 XCF32P
3 59608093 8 XC9500XL
4 0a001093 8 System_ACE_CF
5 632c6093 10 XC5VFX70T
Error Executing xmd Script : D:/Xilinx/12.4/ISE_DS/EDK/data/xmd/flashwriter.tcl
Error :: ERROR: PowerPC405 Version UNKNOWN. The PowerPC405 Config String is NOT Valid
: 0xffffffff
Done!
I can't address  the problem. I need your help.
Best Regard !
hi,
--hem
Visitor liao7wei
Thanks for your help!
