shluo
How to write data into txt file in SDK?
HEY GUYS
I've designed a simple design on a FPGA board, each time it write some data in DDR and i use uart in SDK to print data out using xil_printf. I reset the system every second, it overwrite the data in DDR and then i print it out in the console again.
So my problem is:
1. How can i write the data in a txt file on my computer, instead of copy it from the console.
2.Is there some function other than sleep(), so that i can set an delay less than a second?
it should be easy, i googled, but don't find an answer...
thanks in advance.
stephenm
How you copy the txt file from the PC to your DDR depends on what interface you have available.
Can you list them?
jmcclusk
Mentor
Mentor
Use a serial communications program that will log the output from your serial port.   Kermit, Minicom, putty?    You could even use a python script to listen to the port, with the right python module.
shluo
thanks for answering, the data was generated by hardware and i am reading it out through serial port.
shluo
thanks for the response, in fact i was wondering xilinx provided similar tools in SDK, how about question 2 ? is there some delay function other than sleep() that can set delay less than a second?
