AzU
Importing source code for my Application Project.
I'm in the process of creating an Application through Vivado SDK.
I'll have to follow a tutorial from: http://www.zynqbook.com/download-tuts.html
The problem is that I am stuck in part-f. I've created an Application Project, and I had to import preprepared source code for the application, but when I browse, then I can not find this location in my computer, what should I look for? I am using Zybo.
It says that I've to navigate to C:\Zynq_Book\sources\zybo\zynq-interrupts, but can't really find it.
florentw
Hi @AzU
This is the source download which is on the Zybo page (http://www.zynqbook.com/download-tuts.html)
Ad then whatever the location you have extracted it to
marcb
Hi @AzU
If any of the previous information helped to find a resolution, please mark the helpful post as an accepted solution, for others to find.
