Is it possible to use smartcompile in EDK?
I've seen that there' s a feature in ISE called smartcompile. Is this feature available when using the EDK?
Or is there any other way one can speed up the implementation process?
As even a very small change in some obscure part of the project can consume quite a lot of time to build the new bitfile.... ...it is tiresome!!
Re: Is it possible to use smartcompile in EDK?
SmartCompile is not available from EDK.  You must create an ISE project that contains the EDK project in order to use SmartCompile.  The EDK project can be the top level module in ISE if desired.
Ok.
I've never created an ISE project with an EDK project as the top before. Is it easy? And is there a way back if I don't want to go via ISE anymore?
How is the smartcompile set up?
