mpiechotka
JTAG 'connection drops' when trying to launch ARM application on Zybo (ZYNQ)
I'm unable to use device in any frequency other than 125 kHz - Vivado HW manager doesn't list programmable devices even. With 125 kHz I'm able to program the device and I can even set highier frequencies in xsct console.
However I'm unable to run the C program:
0:51:48 INFO	: 'targets -set -filter {jtag_cable_name =~ "Digilent Zybo 210279A42857A" && level==0} -index 1' command is executed.
00:51:48 INFO	: 'fpga -state' command is executed.
00:51:48 INFO	: Connected to target on host '127.0.0.1' and port '3121'.
00:51:48 INFO	: Jtag cable 'Digilent Zybo 210279A42857A' is selected.
00:51:53 INFO	: 'jtag frequency' command is executed.
00:51:53 INFO	: Sourcing of '/home/mpiechotka/test/test.sdk/test_wrapper_hw_platform_0/ps7_init.tcl' is done.
00:51:56 ERROR	: no targets found with "name =~"APU*" && jtag_cable_name =~ "Digilent Zybo 210279A42857A"". available targets:
  1  DAP (Cannot flush JTAG server queue. ftdi_read_data failed: usb bulk read failed)
  4* xc7z010
  5  whole scan chain (ftdi_read_data failed: usb bulk read failed)
Than Vivado claims that connection to HW server disappeared. When I try to use GDB I get slightly different error and it does not drop the connection:
00:51:02 WARN	: Given IPC port value is invalid. Using default port 2350
00:51:02 WARN	: Given XMD timeout value is invalid. Using default value of 50000
00:51:05 WARN	: Given XMD transaction timeout value is invalid. Using default value of 60000 milli seconds
00:51:07 WARN	: Given XMD transaction timeout value is invalid. Using default value of 60000 milli seconds
00:51:07 ERROR	: Unexpected error while launching program.
com.xilinx.sdk.targetmanager.TMException:
    Cannot flush JTAG buffers
	at com.xilinx.sdk.targetmanager.internal.TM.connectToProcessor(TM.java:478)
	at com.xilinx.sdk.debug.core.XilinxAppLaunchConfigurationDelegate.runTargetSetup(XilinxAppLaunchConfigurationDelegate.java:503)
	at com.xilinx.sdk.debug.core.XilinxAppLaunchConfigurationDelegate.runApplication(XilinxAppLaunchConfigurationDelegate.java:616)
	at com.xilinx.sdk.debug.core.XilinxAppLaunchConfigurationDelegate.launch(XilinxAppLaunchConfigurationDelegate.java:309)
	at com.xilinx.sdk.debug.ui.XilinxAppLaunchDelegateWrapper.launch(XilinxAppLaunchDelegateWrapper.java:31)
	at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:885)
	at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:739)
mpiechotka
Found the problem - I440FX emulation (default) have broken usb redirection. After switching to Q35/nec-xhci it started working.
sadanan
Looks like a problem with cable drivers. Which OS are you using?
mpiechotka
Updated CentOS 7
mpiechotka
ibaie
Hi @mpiechotka,
Can you mark your post as solution?
Ibai
mpiechotka
Sorry. @ibaie I was sure I already done it. Done
zulus.23
Hello
mpiechotka
@zulus.23It depends on what you use to manage the VM. For example in libvirt you need to change machine attribute, for commandline you need to specify machine type in the first place etc.
