matin1
Master local link (plb_master_llink_v3_02_a)
Does any one know if the master local link can  be used as is?  It is not listed in the IP catalog (EDK 9.1)
[The reason I need it is because I am trying to read large amount of data from an external memory and it seems to be able to provide a throughput close to the theoretical throughput of the memory.
I tried to use the master mode of the IPIF (add remove peripheral) and the bandwidth was very not satisfactory)]
Mati
