Anonymous
Not applicable
MicroBlaze MCS simulation with ISim?
 I created MicroBlaze MCS core with coregen and created elf file using SDK. The source code of the C program controls GPO lines and is the copied from a tutorial I found from websearch. It is on page 11.
http://ece.wpi.edu/~rjduck/Microblaze%20MCS%20Tutorial.pdf
 Then I ran the tcl script to create bram files. Then I created testbench which provide clk signal and input to GPI lines and ran behavioral simulation hoping I can see the GPO line changes. ISim ran and started simulation but the GPO signals didn't change. One thing I noticed was when ISim starts, it tries to delete all previous simulation files including bram files. So I got error message that ISim cannot load bram files. I worked around this problem by running tcl scripts again (microblaze_mcs_data2mem command) and pushing Relaunch button on ISim. But still no change on GPO lines.
Is there anyone who tried to simulate MicroBlaze MCS and the program using ISim?
i have same problem ,and dont have any idea :-(
Anonymous
Not applicable
I have tested this in both Vivado, and ISE and it works for me. My flow(s) are seen in the PDF attached.
Note: I used my own script to generate the mem files. This script is placed in the ISE project directory
Hello.
Sorry for bringing this old topic up, but I have exactly the same problem as leofr discribed and I cant solve it. I tried running the script and it seams that generated files are ok, but I can not add them to project as simulation sources (as discribed in pdf). Options are:
Implementation
None
This is what I did:
1) Created new ISE project
2) Added Microblaze MCS and configured it
3) Made a top level hdl file and instantiated the MB core in it
4) Ran synthesis, all runns smooth
5) Created new board support package for ISE my specific project
6) Created C file with code and got .elf file
7) Ran this costume script and got 4 .mem files + disassembled text
8) Added generated .mem files in ISE, but could not associate with simulation...
I also tried running data2mem, I got .mem files, but still I cant add them as simulation sources.
I solved my problem!
In step 5, where I created BSP, I added wrong xml file. The file that should be added is component-name_sdk.xml but I added component -name.xml which resulted incorrect BSP and no output in Isim simulation.
Hi Robert,
I have the same problem with not being able to set the ram files as simulation.
I have use the correctsdk.xml file.
Were you able to set the ram files as simulation or did it just work without doing that?
Thnaks for any help
Andy
Hello! The behavior simulation works well with your method, thanks!
Have you also tried the post place-route simulation? I have not figured out the solution to port the elf file's information to the Post Place-Route Model generated in ISE.
Hai stephanm would u mind explain in detailed on how to create our own script?
Anonymous
Not applicable
Hey Guys,
I have added to the tutorial. The second section
