Microblaze Debugger couldn't debug/run source code on A Vivado 20164 generated Microblaze System
 Hello Xilinx Support team and others,
I am currently encountering an issue that I couldn't run source code debugging on a Xilinx Microblaze system design, which is synthesized and generated on Vivado 20164.
In our case, we created a Microblaze system design based on a Xilinx "base Microblaze design" example, got synthesizing, implementing and generating bitstream file successes.
Then based on this design created HW platform, BSP, and then created a "hello world" example application project. We were able to compile and created EFL file of project, We also could download the combined download.bit file to a KC705 board. We confirmed "Hello World " string was output on UART .
Next, I would like to try run the system and application through a debugger. I setup a GDB debugging session for the application. Started Debugger to run the application code.
The debugger connected to MDM correctly.
However, the debugger didn't stop at main function even I configed "Stop at main() when debugging" in debug configurations.
and, the program went to somewhere like below address without doing anything.
exit() 0x000019bc.
The very interesting thing is, this issue didn't happen if the microblaze system is synthesized and generated by vivado 20154.
Does Vivado20164 need any configuration to generate proper system? or this is a bug ? Any solution or workaround for this issue?
Thanks in advance,
Tong
Hi @ignis_tliu,
We still support GDB but we recommend to use system debugger.
Can you try to clean your project and re-build it and try again with system debugger?
Florent
Florent
Hi @ignis_tliu,
I have already answered the same issue today on the forum:
https://forums.xilinx.com/t5/Embedded-Development-Tools/Unable-to-single-step-or-Stop-at-Main-with-SDK-2016-4/m-p/756335
The solution is to use the system debugger (which is the xilinx tool) instead of GDB
Kind Regards,
Florent
Florent
Thanks for your replying,
Tried to use system debugger. After started debug session, the program stop at beginning of main function - I guess, however it's not within c source code windows, it jump into disassembly window. How could I make system debugger stop show break point in C source code window?
Also, If GDB debugger is no longer supported, should you remove it from debug configurations? That would reduce a lot of user confusion.
Tong
Hi @ignis_tliu,
Florent
Florent
Does this approach not affect the use of JTAG-UART?
 thanks
Hi @spring1919,
No it does not.
Please create a new post if you have an issue.
Florent
Florent
