Visitor beth777
Microblaze application development make file
Hi All
I am trying to develop a make file for the microblaze architecture to build some static libraries for Rhapsody.
I am starting from a QNX makefile that I know works and this file uses a .conf file to setup the compiler : gcc_ntoppcbe.conf.
It is set by the following line in my make file :
CC=qcc -V$(GCC_VERSION)gcc_nto$(CPU)$(CPUEXT) -lang-c++
where the values are set by
    $(MAKE) all -C oxf -f QNXoxf.mak VERSION=650 CPU=ppc CPUEXT=be CFG=oxf
Can someone tell me if it is possible to do this with the microblaze or do I need to use the SDK application to build the static libraries.
Re: Microblaze application development make file
Hi @beth777
You can always create a custom Makefile based application within the SDK. I would recommend you to create a wizard based library and use it as a guideline as well as your QNX one.
https://www.xilinx.com/html_docs/xilinx2018_2/SDK_Doc/SDK_tasks/sdk_t_create_new_libproj.html?hl=static%2Clibrary
Ibai
Ibai
