Migrating Xilinx SDK 2016.4 to Xilinx SDK 2019.1
I have several standalone library/application projects in Xilinx SDK 2016.4 that I need to migrate to Xilinx SDK 2019.1.
In Xilinx SDK 2019.1, I've created a new workspace with a new Hardware Platform Specification project, CPU0 and CPU1 BSP projects, and a static C++ library project. The target processor is a Zynq 7000 series (ARM Cortex A-9).
In Xilinx SDK 2016.4, I used the Xilinx ARM GNU Toolchain with the arm-xilinx-eabi-gcc, arm-xilinx-eabi-g++, and arm-xilinx-eabi-ar commands.
In Xilinx SDK 2019.1, arm-xilinx-eabi does not exist, so attempting to compile using the same toolchain results in:
process_begin: CreateProcess(NULL, arm-xilinx-eabi-g++ -Wall -O0 -g3..., ... ) failed.
make (e=2): The system cannot find the file specified.
I switched to the Xilinx ARM v7 GNU Toolchain with the arm-none-eabi-gcc, arm-none-eabi-g++, and arm-none-eabi-ar commands.
Attempting to compile with Xilinx 2019.1 results in several errors:
"Error: selected processor does not support 'isb' in ARM mode"
"Error: selected processor does not support 'dsb' in ARM mode"
"Error: selected processor does not support 'dmb' in ARM mode"
I've attached a workspace with sample code that generates the mentioned errors.
Are there any compiler options which will allow me to use the arm-none-eabi commands in place of the arm-xilinx-eabi commands? Or is there a way to obtain the arm-xilinx-eabi commands for 2019.1?
Re: Migrating Xilinx SDK 2016.4 to Xilinx SDK 2019.1
Hi @pvempati ,
Thank you for the response. That is my current process. I created a 2019.1 workspace and a new static library project. Then I linked my pre-existing code into the new workspace. The pre-existing code is a mixture .h, .cpp, .c, and .S files. The default compiler options are
-Wall -O0 -g3 -cc -fmessage-length=0 -MT"$@"
With these compiler options, I receive the errors from the original post:
Error: selected processor does not support 'sev' in ARM mode
In the help documentation, under the "Creating a Library Project" section, there is a table which indicates I should use "Extra Compiler Flags" for the "A9" processor. After adding the flags, the full set of compiler options is:
-Wall -O0 -g3 -cc -fmessage-length=0 -MT"$@" -mcpu=cortex-a9 -mfpu=vfpv3 -mfloat-abi=hard
I no longer receive the previous errors. However, I now receive the following compiler errors:
Error: selected processor does not support 'vrev64.8 D0, D0' in ARM mode
vrev64 is a NEON instruction, so I modified my compiler options to:
-Wall -O0 -g3 -cc -fmessage-length=0 -MT"$@" -mcpu=cortex-a9 -mfpu=neon-vfpv3 -mfloat-abi=hard
Now my static library is building correctly.
Hi @bergermeister ,
Yes, Compiler got modified from 2016.4 to 2019.1.
Earlier toolchain was supporting soft-float but to optimize the code we have the new toolchain which supports hard-float.
To migrate your project I would recommend to create an empty project in 2019.1 SDK and copy the sources from 2016.4 SDK workspace.
Hi @pvempati ,
