Missing files in Zynq_PCIe_TRD_2014.4
Good day!
I'm trying to build the Zynq SW Application as it written in TRD Wiki . But on the last step of building 8.2 item (zynq_pcie_qt building) I've got some errors. Briefly, compiler cannot find files:
  • qt_app/cmdline.cpp
  • hw_ctrl/dtsmodel.cpp
  • hw_ctrl/screensaver.cpp
  • hw_ctrl/visibilityanim.cpp
These files are used in the $ZYNQ_TRD_HOME/software/zynq_ps/xsdk/zynq_pcie_qt/Makefile but are absent anywhere!
The files are neither in the rdf0287-zc706-pcie-trd-2014-4.zip nor in the Petalinux directory nor in the Xilinx SDK.
Could someone give the cue where to find these files or add it in the new version of the rdf0287-zc706-pcie-trd-2014-4.zip?
Re: Missing files in Zynq_PCIe_TRD_2014.4
hi,
as i understand these files are not needed for the latest version of TRD. here are the files that you requested for
--hs
