Mix C and assembly Code
Hello guys , I would like to find a tutorial or example on how to mix C and Assembly code for the Cortex-A9 from the SDK .
I have done that many times but on KEIL (which still uses ARM GCC compiler and ARM Assembler) , but its not working for Xilinx SDK .
Simply I wanna define header file for a function as "extern" and then "export" the function body which is written in separate assembly file . This is what I do in KEIL :
 in the .c file :  extern float sqr_root (float x);
then in the .s file :
AREA asm_func, CODE, READONLY
EXPORT sqr_root
sqr_root
VSQRT.F32 s0,s0
BX LR
Any idea on how to do the same on xilinx SDK ?????
Thx in Advance
Tags (3)
Re: Mix C and assembly Code
Why not keep using GCC?
On another tack, one of the things I was always taught when adding assembly code to an algorithm was to first build the algorithm in C, and then between the header and footer of the algorithm stuff the asm() statement.  The result might look something like,
// in the .c file
float sqr_root(float x) {
#ifndef C_SOLUTION asm(" VSQRT.F32 s0,s0 BX LR");
#else
return sqrt(x);
#endif }
Dan
 @dgisselq I understand this in-line assembly man , but I 'm just trying to use multi-file method , it's more mature for me and have used it all the time , any ideas ? ?
Sorry for late response :)
