Moving SDK workspaces with custom IP cores.
I've made a few custom AXI cores complete with drivers for a few designs I am working on. I'm able to generate a BSP with the driver files inside. However, if I move the SDK workspace to a different machine and change/clean the BSP it no longer can generate the driver sources needed to access the custom cores.
Is there a way to somehow have Vivado or SDK make a copy of the drivers and put them in a location in the SDK workspace and reference the copy in case the BSP needs to be cleaned or changed?
Re: Moving SDK workspaces with custom IP cores.
If you point to your drivers from Xilinx Tools -> Repositories, it will always grab them if it needs to regenerate the BSP.
www.xilinx.com
- Minus Kudo
Does not answer the question!
