Participant cau4kien
New created BSP gets errors when building basic start up platform
Using
Xilinx Software Development Kit
Release Version: Release 14.7 Build SDK_P.20131013
I have created a new BSP for Spartan6 design with Microblaze and AXI bus protocol, because I have problem with integrating the AXI_INTC (interrupt controller), so I try to move on without the AXI_INTC for now. the BSP omitted the header files for intc IP such as xintc_l.h etc ... I manually added in those hearder files so the building process can proceed further to the point the error occurred causing by the the module "profile_mcount_arm.s" regarding the Assembler as below:
"profile_mcount_arm.s" source code:
// based on "ARM Profiling Implementation" from Sourcery G++ Lite for ARM EABI
.globl
__gnu_mcount_nc
.type
__gnu_mcount_nc, %function
__gnu_mcount_nc:
push {r0, r1, r2, r3, lr}
subs r1, lr, #0
/* callee - current lr */
ldr r0, [sp, #20]
/* caller - at the top of the stack */
bl mcount
/* when __gnu_mcount_nc is called */
pop {r0, r1, r2, r3, ip, lr}
bx ip
.end __gnu_mcount_nc
error messages are:
"characterization_bsp/microblaze_0/libsrc/standalone_v3_11_a/src/profile/profile_mcount_arm.o" "../characterization_bsp/microblaze_0/libsrc/standalone_v3_11_a/src/profile/profile_mcount_arm.S"
../characterization_bsp/microblaze_0/libsrc/standalone_v3_11_a/src/profile/profile_mcount_arm.S: Assembler messages:
../characterization_bsp/microblaze_0/libsrc/standalone_v3_11_a/src/profile/profile_mcount_arm.S:26: Error: unknown opcode "push"
../characterization_bsp/microblaze_0/libsrc/standalone_v3_11_a/src/profile/profile_mcount_arm.S:27: Error: unknown opcode "subs"
../characterization_bsp/microblaze_0/libsrc/standalone_v3_11_a/src/profile/profile_mcount_arm.S:28: Error: unknown opcode "ldr"
../characterization_bsp/microblaze_0/libsrc/standalone_v3_11_a/src/profile/profile_mcount_arm.S:29: Error: unknown opcode "bl"
../characterization_bsp/microblaze_0/libsrc/standalone_v3_11_a/src/profile/profile_mcount_arm.S:30: Error: unknown opcode "pop"
../characterization_bsp/microblaze_0/libsrc/standalone_v3_11_a/src/profile/profile_mcount_arm.S:31: Error: unknown opcode "bx"
../characterization_bsp/microblaze_0/libsrc/standalone_v3_11_a/src/profile/profile_mcount_arm.S:33: Error: missing .func
make: *** [characterization_bsp/microblaze_0/libsrc/standalone_v3_11_a/src/profile/profile_mcount_arm.o] Error 1
21:46:27 Build Finished (took 1s.480ms)
Also see the attachment.
How can I fix this or I have to intergrate the AXI_INCT IP to use with the MicroBlaze processor?
Re: New created BSP gets errors when building basic start up platform
Great. Can we mark this forum post as solved? Let us move on to the other INTC issue :)
--Hem
Oooops, I attached a wrong snapshot, forum moderator please remove it.
Here is the right one.
Can you attach the workspace? It looks that you are trying to compile the application with profile configuration.
--Hem
Hi Hem,
Attached is the zip file of my software development, which included:
         - the hardware platform folder,
         - the initial application folder (which only has the hello_world.c program ...lol)
         - and the BSP generated by SDK.
I just simply build the project with hello_world.c then the error occured.Try to locate where to put the assembler, but don't know how.
I have used the SDK for couple years with the Virtex 6 family and MicroBlaze similar to this, but never seen this before
Please help.
K
Do attach your xml file also.
--Hem
Hem,
I DELETED whole directory even the ISE workspace, then created everything from scratch. it works fine !!! still have to manually added the intc.h, intc_l.h hearder files related to axi_intc ip,( which I still have problem).
The tool was not smart enough to recognize that the axi_intc ip was omitted, because I can move on without it for now.
Anyway, thank for your help. If you can look at my other issue related to integrate the axi_intc in XPS I would deeply appriciate.I already sent the issue description to my local FAE, but no one is availble to help until sometime next week  :-(
K
--Hem
