01-30-2017 03:54 AM
Hi There!
I'm trying to create a project to run VxWorks on PPC440 of Virtex 5 FPGA using Xilinx ISE 14.7.
I'm following the xilinx manual XAPP1114.
While creating a new bsp project, I'm not able to find the VxWorks entry option under OS:
Please suggest how to enable vxworks
02-05-2017 05:33 AM
If you have Vxworks BSP compiled for boards like you have pointed out for e.g. - 'C:\Xilinx\14.7\ISE_DS\EDK\sw\ThirdParty\bsp\vxworks6_7_v1_03_a it can be enabled by editing in its MLD file.
All you need to do is make parameter OPTION OS_STATE = ACTIVE; in .mld file.
Once you save the file export design to SDK and create BSP. It should generate bsp.
Praveen
02-01-2017 07:57 PM
hi,
xapp1114 is targeting EDK 10.1. can you check any previous releases?
--hs
02-01-2017 11:32 PM
Hi, Thanks for your input.
I'm following the XAPP1114 note but, I have Xilinx ISE 14.7 version and I have to use this and generate an VxWorks v6.7 BSP.
I'm able to see directories in Xilinx installation related to VxWorks @ C:\Xilinx\14.7\ISE_DS\EDK\sw\ThirdParty\bsp\vxworks6_7_v1_03_a, but VxWorks option is not visible in New BSP creation window of Xilinx SDK. I'm looking on how to enable this in Xilinx SDK 14.7.
-Kumar
02-05-2017 05:33 AM
Praveen
02-08-2017 09:24 PM
Hi @pvenugo, Thanks for your reply and it works. I'm able to create vxworks bsp in xilinx 14p7 SDK.
