Voyager
Voyager
No source available for ...
I have develop a simple program that use an assebler file ".s", but I can not debug, debugger replay with "No source available for add()".
I use EDK 13.2 on Spartan 3A 3400 DSP.
This is a example of "add" code written in assembler :
"main.c" :
#include "stdio.h"
#define	TRUE	        1
#define	FALSE 	0
extern unsigned int add(unsigned int x, unsigned int y);
int main(void)
	unsigned int a, b, result;
	a = 10;
	b = 20;
	while(TRUE)
		result = add(a, b);
		xil_printf("a [%d] + b [%d] = result [%d]\r\n", a, b, result);
		a += result;
		b += result;
	return 0;
"add.s" :
    .text
    .globl	add
    .ent	add
    .align  2
add:
    ADD 	r3, r5, r6
    NOP
    NOP
    NOP
    RTSD    r15, 8
    NOP
    .end	add
I add a breakpoit on "add" in C code (all are ok) :
main
I already place a breakpoint on assembler file "add.s" (the breakpoint seem valid) :
add
Now I start the debugger an go to "add.s" code, but previous breakpoint make a warning : "unresolved breakpoint"
add breakpoint
If I press "Resume F8", the program start but breakpoint on "add.s" never occour. I then placed the preakpoint with XMD using this command "bps 0x1b0 sw" (0x1b0, code is in BRAM). I press "Resume F8" and now breakpoint occour but no source code "add.s" is visible :
add no source
I press "View Disassembly" and this appear :
add debug F5
But if I use "Step into F5" the assembler code is not execute and I return to C code. The routine is execute completely without step on assembler code.
Does anyone have a solution ? In EDK 13.2 is not possible to program in assembler ? Why ?
secureasm
Visitor zenghs
Re: No source available for ...
 I have the same question with you ,did you resolve it ?
Rename assembler code with "extension in upper case" :
add.s ===> becomes ===> add.S
debugasm
