OPB_UART 16550 ???????
You used opb_uart 16550????? Today i try to use it but appear errors . You can see figures :
ERROR
INFO:coreutil - Valid license for feature opb_uart16550_v1_00_c not found.
You may use the customization GUI for this core but you will
not be able to generate any implementation or simulation files.
Contact Xilinx to obtain a full license for this LogiCORE. For more
information please refer to www.xilinx.com/ipcenter/ipevaluation/
FLEXlm Error: No such feature exists (-5,21)
ERROR:MDT - opb_uart16550 (rs232_uart_1) - C:\thanh\system.mhs:127 - invalid
license or no license found!
plb_v34 (plb) - C:\thanh\system.mhs:97 - 2 master(s) : 3 slave(s)
opb_v20 (opb) - C:\thanh\system.mhs:106 - 1 master(s) : 5 slave(s)
ERROR:MDT - Errors occured while creating Hardware System
make: *** [ppc405_0/lib/libxil.a] Error 2
Done.
I visit "www.xilinx.com/ipcenter/ipevalation/" but my request was denied because i don't have product ID number . If you used it before , you can show me how  i can use it >thank you
Well not sure thats old wait a couple days and buy ISE/EDK 9.2 when its released
Are you student?
Cheers,
Bill Tomb
OPB UART 16550 is a licensed core.
Usually EDK will contain evaluation licenses, which will be expired in one year after it's released.
It seems that you are using EDK7.1. The evaluation license must have been expired.
--XF
Just try to change your pc clock back
Cheers,
Bill Tomb
YES,  I using EDK 7.1i . So really no way to help me using OPB_UART 16550 .  Any way  thank your replies .
You could try using the opb_uartlite instead.
You might need to change some program files so they include the driver for the uartlite instead of the uart550
Göran
