Object file that microblaze generates
 Can anyone tell me where does microblaze stores the output file of compile phase (object file), which is the file just one step above executable.elf. I want to see the assembly instruction which microblaze generates for C code.
Re: Object file that microblaze generates
Rai,
You can disassemble the elf to see the assembly instructions. For example,
$mb-objdump -Ss executable.elf > objfile.txt
This file should have alll the assembly instructions for your code.
Hope this helps.
Thanx for ur reply.
Can u please tell us a way to do the timing analysis of whole design (s/w + h/w) using xps ..... we tried profiling using SDKand XPS  but were not able to make it work.....
