Visitor stone9502
PLB46 to DCR bridge
In my design, I have one microblaze processor and one PLB46 bus, for using the DCR interface, I add one PLB46 to DCR bridge IP to the EDK system. two problems emerge after I add this IP:
1: Once I add this IP to the design, the block diagram will not be generated. If I remove this IP, then the block diagram can be generated again
2: I assigned the address to the PLB46 to DCR bridge and connect it to the SPLB, but the address is not mapped to the microblaze processor's address space. (The DCR interface in the PLB46 bus are included.)
http://lh3.ggpht.com/_CkRzrKTpRMU/SwXAh7E-bII/AAAAAAAAAuo/zJlv-SSNY68/Snap1.jpg
 http://lh6.ggpht.com/_CkRzrKTpRMU/SwXAiC48zmI/AAAAAAAAAus/fAt2MGV07zw/Snap2.jpg
The EDK I used is 11.3, and the bus connection can be found in the following fig, what's wrong with it?
 Thanks!
Message Edited by stone9502 on 11-19-2009 01:42 PM
Message Edited by stone9502 on 11-19-2009 02:06 PM
Message Edited by stone9502 on 11-19-2009 02:10 PM
Tags (3)
Scholar drjohnsmith
Re: PLB46 to DCR bridge
don't know is the easy answer, mainly as the pictures you posted have not come out .
 what format have you used ?
Visitor stone9502
Hi, Drjohnsmith,
The picture should display correctly now, the forum doesn't support insert picture directly, I have to upload it somewhere.
thanks
Visitor stone9502
Can anybody who is using the EDK try this IP to find out why it can not mapped to the microblaze's address space? I am wondering whether that's a bug.
Thanks!
Observer sepher
Hello!
Try the following-> go to 'Addresses' tab in the 'System assembly' window and click on 'Generate addresses' button (upper right corner of the tab).
Visitor stone9502
hi, sepher
Actually, I've tried that, it doesn't work. And aslo in that way, the system automatically generate the address assignment,
The issue is that the C_BASEADDR on plbv46_dcr_bridge IP is a BRIDGE type address. So, from a software perspective, these addresses are "invisible". The real addresses are those of peripherals on the other side of the bridge (whatever that might be - tft, etc...).
The XPS address map will show all real addresses as part of address map, but does not show bridge type addreses. This should only be a visual issue as it looks like the batch tools like libgen/platgen still work correctly.
This is a known issue and a defect has been filed to fix this in the future.
So to clarify a bit further, you will need to manually update the address info in the GUI, or in the MHS, and should be able to build without any errors.
