kre8si
PLBv46_PCIe bridge Interrupt?
is there any way to send an Interrupt to HOST PC with PLBv46_PCIe bridge, not over Message Signal Interrupt!?
Because i work with Windows XP i can't use MSI.
- Or is there neverthelessb a way to use MSI: Enable MSI over the PCIe Configuration Space. Would this work? How then i enable the Interrupt for Windows XP.
- Can i use the PCIeEndpointBlock Plus with normal legacy Interrupts in combination with the PLBv46_PCIe bridge?
kre8si
Jes,
I'm afraid so. But the integrated Endpoint Block Plus within the Bridge supports also legacy Interrupts!
So i do the work and now my Bridge supports legacy Interrupts too :-).
I had to change the InterruptPin-Register [UG197 page 53], [UG341 page 90] and the Process in witch the MSI_Interrupt generate the signals for the Endpoint Block [UG341 – page 101]. You can use the code to set the register as it is implemted for the Virtex6 Root Complex in the registers.vhd. You have to connect the following signals similar for the Virtex6 RC:
cfg_do
sig_mgmtrdata
cfg_rd_wr_done_n
sig_cfg_rd_wr_done_n
cfg_di
sig_mgmtwdata
cfg_byte_en_n
tied_low(0 to 3)
cfg_dwaddr
sig_mgmtaddr(1 to 10)
cfg_wr_en_n
"1011" - for only write on the InterruptPin register
I hope this helps.
karlk
The PCIe bridge only supports MSI interrupts.
kre8si
Jes,
cfg_do
sig_mgmtrdata
cfg_rd_wr_done_n
cfg_di
sig_mgmtwdata
cfg_byte_en_n
tied_low(0 to 3)
cfg_dwaddr
cfg_wr_en_n
I hope this helps.
olzetek_dhpark
Hi kre8si, I'm looking a solution to generate PCIe interrupt. The endpoint is SP605 board and the root complex is windows PC. I want to generate legacy interrupt( endpoint -> root complex). I used the "plbv46_pcie 4.06a" IP. I read your message. But I did not understand your description. Could you explain more detail? How to change the registers.vhd file? And what to do generate the interrupt? Thanks.
