PYNQ Z1 UART0
I am trying to send data via usb serial port from my PC to my PYNQ-Z1 board using the PS UART0 in the pynq board with jupyter notebook python code, any idea how to do it?
Ashwini_Miskin
The below link for PYNQ-Z1 Setup Guide has all the information regarding the board settings, network connection and the way of accessing and transfer files to and from the board. Hope this should be helpful.
https://pynq.readthedocs.io/en/latest/getting_started/pynq_z1_setup.html
Ashwini
Give kudos if helpful. Accept as solution if it solves your problem.
marcb
Hi @Abdelrahmanadel
If any of the previous information helped to find a resolution, please mark the helpful post as an accepted solution, for others to find.
