Observer zer0c00l
Petalinux UartLite garbage
I have implemented the following design in Vivado
in vivado the uartlite ip is set at 9600 baud, and the rx, and tx pins are set on JC on the IOCC card. In petalinux when I try to do an echo like echo "abcdefg" > /dev/ttyUL1 I just receive garbage on the other end. I am using a USB to RS232 cable
Observer zer0c00l
Re: Petalinux UartLite garbage
PROBLEM SOLVED
It turns out the USB to RS232 cable that I have been using expects 12v logic levels. I tried communicating with another micro-controller which also operates at 3.3v and it works without any problems.
Observer zer0c00l
Ok this is weird. I added AXI UART16550, and tested that. It is also giving me the same garbage values. I have verified the baud rates, and tried different cables. Any ideas anyone?
Observer zer0c00l
I tried the builtin 16550 hello world application in SDK, and that too sends garbage instead of Hello World. I have tried all possible baud rates with no luck. Could the problem be the way my interrupts are connected?
Here is the full design
Observer zer0c00l
PROBLEM SOLVED
