Petalinux-build in 2015.4 ERROR: Invalid ELF file
I have installed petalinux 2015.4 and created a project with the AVNET...2015.4.bsp like:
petalinux-create -t project -s AVNET...bsp
I tryed to did petalinux-build but it failed. I do not understand, because I installed these libraries:
sudo apt-get install tofrodos iproute gawk gcc git-core make net-tools ncurses-dev libncurses5-dev tftpd zlib1g-dev flex bison lib32z1 lib32ncurses5 lib32bz2-1.0 ia32gcc1 lib32stdc++6 libselinux1
I had a problem with lib32bz2-1.0 and ia32gcc1. Because the log said that these libraries are outdated. But i think that it is not the problem.
I send you the log of my petalinux-build. I hope you can help me.
Regards.
I have the similar issue. How did you solve this ?
