Post PAR files from EDK Run
Is it possible to generate some sort of post place and route netlist directly from EDK 14.7 without having to go to the hassle of creating a new ISE project?
Lachlan Grogan
CEO, SIL3 Pty Ltd
Melbourne, Australia
http://sil3.com.au
Community Manager
Community Manager
Re: Post PAR files from EDK Run
Yes you should be able to generate all post implementation ncd files and bitstream file from EDK/XPS project itself.
These will be located in the implementation folder when you generate bitstream from the GUI.
http://www.xilinx.com/itp/xilinx10/help/platform_studio/ps_r_gst_xps_project_directories.htm
Hope this helps.
Sikta
Community Manager
Community Manager
Hope this helps.
Sikta
Thanks for your response.
Do you know if there is an application note or otherwise showing how to use a tool like NetGen to take our top level NGC and some timing file (SDF?) and merge into a verilog or VHDL simulation file?
Lachlan Grogan
CEO, SIL3 Pty Ltd
http://sil3.com.au
Community Manager
Community Manager
@lockiegrogan Glad that this is helpful.
This would be a different question. I would suggest creating a new thread in Simulation and verification board to get experts help.
On a general note,
  • For a functional netlist, use:
    netgen -ofmt {verilog|vhdl} [options] input_file[.ngd|ngc|ngo]
  • For a timing netlist and SDF, use:
    netgen -sim -ofmt {verilog|vhdl} [options] input_file[.ncd]
    (Refer to Xilinx’s UG628 Command Line Tools for detailed instructions on how to use this command).
