Voyager
Voyager
Printing the DHCP aquired configuration.
Can any one suggest how to print the newly acquired DHCP configuration after using the dhcp_start(netif) function. ?
Tags (3)
Re: Printing the DHCP aquired configuration.
So in one thread after dhcp_start, manage the counters as follows:
    // Start the DHCP "Client Daemon"
    xil_printf("Starting DHCP_CD...\r\n");
    dhcp_start(netif);
    while (1) {
        sleep(DHCP_FINE_TIMER_MSECS);
        dhcp_fine_tmr();
        millisec_cnt += DHCP_FINE_TIMER_MSECS;
        if (millisec_cnt >= DHCP_COARSE_TIMER_SECS*1000) {
            dhcp_coarse_tmr();
            millisec_cnt = 0;
Then in another thread, wait for the network to negotiate, then wait for an IP address to be assigned.
    //wait for network link to negotiate
    print("Waiting for network interface to negotiate\n\r");
    while (1) {
            sleep(500);
            if(netif_is_up(netif)) {
                   xil_printf("Network interface up\n\r");
                   break;
    // Wait for DHCP IP configuration
    while (1) {
        if (netif->ip_addr.addr) {
            xil_printf("DHCP request success\r\n");
            break;
        if (millisec_cnt >= DHCP_TIMEOUT_MS) {
            xil_printf("ERROR: DHCP request timed out\r\n");
            return;
    /* print out IP settings of the board */
    print_ip_settings(&netif->ip_addr, &netif->netmask, &netif->gw);
See attached for full main.c
Voyager
Voyager
Hey John
i am working with a single threaded system using RAW APIs. So.. i was trying another method using the netif set status callback function . I have attached the main c file in this. Is it the correct way of doing it for a single threaded system?
I am still facing some errors so working on it. But in gereral is it the right concept?
Sorry but I can't help you as I haven't looked at this portion of lwip for a few years. I was hoping my working code snippet would have been enough to get you rolling.
One thing I would check is that your timers are working. I'm not sure what errors you've been experiencing. Also, use wireshark to make sure you are receiving dhcp responses.
Voyager
Voyager
Thank you John.
I will try and adapt your code snippet into the single threaded system .
