waseem
Problem in understanding behaviour of aarch64-none-elf-gcc compiler on Neon intrinsics for ARM cortex a53
I am using Xilinx SDK 2019.1 for my application and running it on ARM cortex a53  processor with Neon and floating point engine support available.
The problem I am facing is that, I am unable to understand the disassembly of neon intrinsics functions in my code at highest level optimization i.e O3.
The code is simple. I am giving as an input two floating point arrays of each 16 elements and then multiplying each 4 elements chunk of array A with array B and storing its result in array C.
The C version of my code is:
// initialized arrays
float A[16]= {1.0,2.0,3.0,4.0,
1.0,2.0,3.0,4.0,
1.0,2.0,3.0,4.0,
1.0,2.0,3.0,4.0
float B[16] = {1.0,2.0,3.0,4.0,
1.0,2.0,3.0,4.0,
1.0,2.0,3.0,4.0,
1.0,2.0,3.0,4.0
float C[16];
//function definition
#include <arm_neon.h>
void multiply_4x4_neon(float *A, float *B,float *C) {
// these are the columns A
float32x4_t A0;
float32x4_t A1;
float32x4_t A2;
float32x4_t A3;
float32x4_t B0;
float32x4_t B1;
float32x4_t B2;
float32x4_t B3;
float32x4_t C0;
float32x4_t C1;
float32x4_t C2;
float32x4_t C3;
C0 = vmovq_n_f32(0);
C1 = vmovq_n_f32(0);
C2 = vmovq_n_f32(0);
C3 = vmovq_n_f32(0);
A0 = vld1q_f32(A);
B0 = vld1q_f32(B);
C0 = vmlaq_f32(C0,A0, B0);
vst1q_f32(C, C0);
A1 = vld1q_f32(A+4);
B1 = vld1q_f32(B+4);
C1 = vmlaq_f32(C1,A1, B1);
vst1q_f32(C+4, C1);
A2 = vld1q_f32(A+8);
B2 = vld1q_f32(B+8);
C2 = vmlaq_f32(C2,A2, B2);
vst1q_f32(C+8, C2);
A3 = vld1q_f32(A+12);
B3 = vld1q_f32(B+12);
C3 = vmlaq_f32(C3,A3, B3);
vst1q_f32(C+12, C3);
The assembly of above code at zero optimization level and at O3 optimization level is attached in text format.
I could not understand that there are so many load/store and other redundant instructions at zero optimization level.
The setting of compiler is attached. I am not using any compiler option for optimization. My doubt is that I need to tell the compiler to use hardware linkages to avoid
this loading and storing data like I should use -mfloat-abi=hard in optimization setting of compiler but I am unable to set this option as my compiler is not recognizing it.
All of my variables are also local too.
For O3 optimization, I could not understand the disassembly.
I could not understand why there is a function body of vst1q_f32 (float32_t *a, float32x4_t b)  intrinsic function starting in the middle of assembly code.
I know that at highest optimization level, the compiler is somehow jumping around the instructions.
Could someone please help me on these confusions?
waseem
Any one who can help on this question?
