Problem of ISIM simulation of microblaze project
I have a SP605 board with ISE 14.4 installed on Windows 7 OS. I have built a small Microblaze project. It is a xilkernel project, which blinks LED plus UART xilprintf. In fact, it is modified from the xilkernal example project. It can be downloaded to SP605 board and runs OK.
I want to go through ISIM simulation. I have added .elf to ISE project navigator project. I associate the .elf with simulation project and bootloop to the implementation project. When ISIM run the simulation, I notice that the Microblaze instruction address goes from (at 1.2 uS) 00000000,00000004,00000008, 00000000c, 00000050, 00000054,00000058,0000005c.......000001f8. Then, it cycles 000001e4,00000001e8,0000001ec, 000001f0,000001f4,000001f8,000001e4,0000001e8......
It cycles even for several mS. I don't think it runs my application. It runs bootloop? What is wrong with the simulation?
Re: Problem of ISIM simulation of microblaze project
Excuse me. I forgot th say that I use 64 KB block ram for code, without using external DRAM. I want the system simple enough to run the ISIM simulation. But it does not work. Could you help me? thanks
