Problem with XPS SDK
I have a problem when opening the XPS SDK from my project in XPS project. That after selecting Software-> Launch Platform Studio SDK to launch the SDK application to create the software executables, the console windows of XPS SDK is open and close instantly.
And if I'm trying to open XPS SDK form program menu of Windows XP, it gives an error message that is "could not find the main class. Program will exit" Although i have the Memory_test, and Perpherial_test application that was created by BSB and it contain "main".
I'm using Xilinx ISE desgin suite 10.1
Hoping to hear from you soon, thank you in advance.
Best Regards.
Hamzah A. Abdel-Aziz
It is OK, I sloved it.
I have to put my project in a directory that doesn't contain any space or blank. Also I setuped a JER.
Many thanks.
Message Edited by hamzah.aaaa on 10-22-2008 12:20 AM
Best Regards.
It seems this "main" in the error message is not the main() function in your program.
Searching Google tells me this error maybe related to the jre version.
SDK (Eclipse) is programmed in Java.  This error means SDK encounter errors when launching.
It's not related to your custom project.
Do you install seprate JRE on your computer?
No.
Actually i reInstall a fresh version of windows xp, and XPS but the problem still exist.
Should I install a thirdy part JER program? or what?
Thanks a lot.
Best Regards.
Many thanks.
Best Regards.
