Problems running Zynq UltraScale MPSoC Base TRD 2017.1 - Design Module 5
I run the TRD 2017.1 - Design Module 5 in petalinux 2017.2, following the build flow provided in the link below:
http://www.wiki.xilinx.com/Zynq+UltraScale+MPSoC+Base+TRD+2017.1+-+Design+Module+5
When I build the project, I meet the build error showed in the following image.
Re: Problems running Zynq UltraScale MPSoC Base TRD 2017.1 - Design Module 5
If you can see the errorr: Includes nested too deeply, which means you are creating the project in the folder inside folder inside folder, which is causing the problem. Try creating the project in your /home/user directory or /home/user/trd
Best Regards
Shabbir
Best Regards
Shabbir
Hi Shabbir,
Thanks for your help. Now we can build TRD2017.2 DM5 and run it on board.
But we got another problem. We want to use USB webcam instead of TPG. But it doesn't work. we tried Logitech HD Pro Webcam C920, but nothing happens. We want to know if anyone has used USB webcam on TRD projects? What's the USB webcam model? Does it require any special settings? Thanks you very much.
