Problems using USB webcam in Zynq Ultrascale MPSoC TRD2017.2 DM5
We can build and run DM5 on board. But there is only TPG source. Nothing happens even after we plug-in USB webcam via USB hub (the USB mouse works OK).
We want to know if anyone has used USB webcam on TRD projects? What's the USB webcam model? Does it require any special settings? Thanks you very much.
Re: Problems using USB webcam in Zynq Ultrascale MPSoC TRD2017.2 DM5
Problem solved!
We use USB webcam <Logitech HD Pro Webcam C920>, and make sure plug-in the camera before running apps.
Problem solved!
