09-17-2019 08:17 AM
I'm able to profile a single core system, but I failed to profile a single core in a dual core system.
What special settings/scripts are required to do that?
Thanks!
Martin
09-27-2019 07:32 AM
Hi @mkugler
Do you mean that profiling works if you target single core Zynq-7000 but fails if using dual core Zynq-7000? Which release of the tool are you using? Any other detail of your setup and the septs you are following might help the community to understand the use case.
10-28-2019 03:45 AM - edited 10-28-2019 09:39 AM
Dear Ibaie,
this question is related to dual Microblaze system.
We can do all the three ways of profiling for a single core HW.
For the dual core the XSDK is not able to select the second core (which has to be profiled).
I was not able to do this with the XSDK and XSCT.
Could you please give an example how to profile our code on any core in multiple core system?
Thank you very much!!!
