jmarcbel77
Program "make" not found in PATH compile issue
I tried to compile a  zynq SDK project with Vivado 2016.2 installed on a Debian 8 linux and have the following error :
Description    Resource    Path    Location    Type
Program "make" not found in PATH    fsbl             C/C++ Problem
Program "make" not found in PATH    standalone_bsp_0             C/C++ Problem
It's seems that SDK can't find the compiler for the SDK.
Does someone already have this error?
Thanks in advance for your help.
Best Regards
JM
florentw
Hi @jmarcbel77,
did you source <installation path>/Xilinx/SDK/2014.4/settings64.sh ?
Florent
Florent
balkris
run this commend
sudo ln -s /usr/bin/make /usr/bin/gmak
Thanks and Regards
Balkrishan
jmarcbel77
I start Vivado 2016.2 with the following commands :
source /opt/Xilinx/Vivado/2016.2/settings64.sh
vivado
and create bitstream and then lauch SDK from vivado menu and select the workspace.
JM
jmarcbel77
Hi Balkrishan,
I run  sudo ln -s /usr/bin/make /usr/bin/gmak
and I have a message that the link already exist
n: impossible de créer le lien symbolique « /usr/bin/gmak »: Le fichier existe
Best Regards
jmarbel77
jmarcbel77
Thanks for your reply
I source with the following command
source /opt/Xilinx/SDK/2016.2/settings64.sh
and try also the following command
sudo ln -s /usr/bin/make /usr/bin/gmake
with the same issue.
I uninstall and reinstall Vivado 2016.Z with SDK with the same issue
I run out of idea.
Best Regards
JM
jmarcbel77
Hi All,
It's seems that Debian 8 Jessie is not an OS supported by Vivado 2016.2
but after investigation, I found the solution to my problem.
The make utility was not installed, I installed the following packages :
apt-get install make
sudo apt-get install build-essential
That fix the make not found error.
After the fix, I have another make error 127. To fix this problem, SDK need the 32 bits library.
I installed the following package :
sudo apt-get install lib32stdc++6
By installing those package make my program compile successfully in SDK.
Hoping this post will help other peoples having the same issue.
Best Regards
jmarcbel77
This solution worked on my Xilinx SDK version 2018.3
Jcadena
This worked for Vitis 2020.1
Running on Ubuntu 20.04. Thanks a lot
