Visitor valex
Programming FPGA error on SDK 13.4
Hi all,
I have a problem trying to program my FPGA with the SDK. After having imported the hardware and implemented a simple code (writing on the uart), I click on the "program FPGA" button and a window appears to select the bootloop (nothing strange until there). I properly select the right path but then an error message appears saying :
< Program FPGA failed
Reason:
FPGA configuration encountered errors.
Program FPGA failed
  Data2MEM failed >
The console ouput :
<FPGA Programming Failed due to errors while initializing bitstream>
I have tried to move the bootloop file in my project directory, it has worked 2 or 3 times without doing any change in the FPGA configuration and until i simulate the code in debug mode.
I hope someone could help, I have searched in the SDK configuration and in my FPGA configuration but i haven't seen where does that problem come from.
I'd really appreciate any help.
Thanks!
Visitor valex
Re: Programming FPGA error on SDK 13.4
Just few more precisions:
- I work on a VIRTEX-5 ML507
- The console also prints:
ERROR:Data2MEM:1 - File '\projet\SW\...\\system.bit' can not be found, or is busy.
Please ensure that the file is available in the correct
directory location, or isn't being locked by another
application.
I have checked that the system.bit is well in the directory and doesn't seem to be used by another application..
Visitor valex
SOLVED
I had to uninstall and re-install Xilinx ISE design.
