12-04-2012 10:59 PM
How could I put DCM module which is generate by architecture wizard into my XPS project? I tried to create a new IP in XPS and paste code in vhdl and usf files generated by wizrad into vhdl and usf files in XPS project. But I got
ERROR:NgdBuild:981 - Could not find any associations for the following
constraint:
constraint:
constraint:
constraint:
constraint:
constraint:
constraint:
constraint:
constraint:
constraint:
constraint:
constraint:
constraint:
constraint:
ERROR:ConstraintSystem:59 - Constraint <INST DCM_SP_INST CLK_FEEDBACK = 1X;>
[system.ucf(582)]: INST "DCM_SP_INST" not found. Please verify that:
1. The specified design element actually exists in the original design.
2. The specified object is spelled correctly in the constraint source file.
ERROR:ConstraintSystem:59 - Constraint <INST DCM_SP_INST CLKDV_DIVIDE = 2.0;>
[system.ucf(583)]: INST "DCM_SP_INST" not found. Please verify that:
ERROR:ConstraintSystem:59 - Constraint <INST DCM_SP_INST CLKFX_DIVIDE = 31;>
[system.ucf(584)]: INST "DCM_SP_INST" not found. Please verify that:
ERROR:ConstraintSystem:59 - Constraint <INST DCM_SP_INST CLKFX_MULTIPLY = 7;>
[system.ucf(585)]: INST "DCM_SP_INST" not found. Please verify that:
ERROR:ConstraintSystem:59 - Constraint <INST DCM_SP_INST CLKIN_DIVIDE_BY_2 =
FALSE;> [system.ucf(586)]: INST "DCM_SP_INST" not found. Please verify that:
ERROR:ConstraintSystem:59 - Constraint <INST DCM_SP_INST CLKIN_PERIOD = 20.000;>
[system.ucf(587)]: INST "DCM_SP_INST" not found. Please verify that:
ERROR:ConstraintSystem:59 - Constraint <INST DCM_SP_INST CLKOUT_PHASE_SHIFT =
NONE;> [system.ucf(588)]: INST "DCM_SP_INST" not found. Please verify that:
ERROR:ConstraintSystem:59 - Constraint <INST DCM_SP_INST DESKEW_ADJUST =
SYSTEM_SYNCHRONOUS;> [system.ucf(589)]: INST "DCM_SP_INST" not found. Please
verify that:
ERROR:ConstraintSystem:59 - Constraint <INST DCM_SP_INST DFS_FREQUENCY_MODE =
LOW;> [system.ucf(590)]: INST "DCM_SP_INST" not found. Please verify that:
ERROR:ConstraintSystem:59 - Constraint <INST DCM_SP_INST DLL_FREQUENCY_MODE =
LOW;> [system.ucf(591)]: INST "DCM_SP_INST" not found. Please verify that:
ERROR:ConstraintSystem:59 - Constraint <INST DCM_SP_INST DUTY_CYCLE_CORRECTION =
TRUE;> [system.ucf(592)]: INST "DCM_SP_INST" not found. Please verify that:
ERROR:ConstraintSystem:59 - Constraint <INST DCM_SP_INST FACTORY_JF = C080;>
[system.ucf(593)]: INST "DCM_SP_INST" not found. Please verify that:
ERROR:ConstraintSystem:59 - Constraint <INST DCM_SP_INST PHASE_SHIFT = 0;>
[system.ucf(594)]: INST "DCM_SP_INST" not found. Please verify that:
ERROR:ConstraintSystem:59 - Constraint <INST DCM_SP_INST STARTUP_WAIT = FALSE;>
[system.ucf(595)]: INST "DCM_SP_INST" not found. Please verify that:
ERROR:NgdBuild:604 - logical block 'dcm_module_0/dcm_module_0' with type
'dcm_module' could not be resolved. A pin name misspelling can cause this, a
missing edif or ngc file, case mismatch between the block name and the edif
or ngc file name, or the misspelling of a type name. Symbol 'dcm_module' is
not supported in target 'spartan3e'.
ERROR:Xflow - Program ngdbuild returned error code 2. Aborting flow execution...
Partition Implementation Status
No Partitions were found in this design.
NGDBUILD Design Results Summary:
Number of errors: 29
Number of warnings: 173
Total REAL time to NGDBUILD completion: 47 sec
Total CPU time to NGDBUILD completion: 46 sec
One or more errors were found during NGDBUILD. No NGD file will be written.
Writing NGDBUILD log file "system.bld"...
make: *** [__xps/system_routed] Error 1
Done!
I don't think it is the right way to do import files. Is there other way to import DCM module?
Thanks in advance.
Best,
12-06-2012 12:31 PM - edited 12-06-2012 12:33 PM
What happens when you press "Validate Clocks" in the clock wizard?
@bs0826 wrote:
Forgot to say.
Why do I get "Please make sure the core specific logic for the following components is in sync with the system changing: proc_sys_reset_0, fsl_i2s_0, dcm_module_0"?
If the clocks change, you need to ensure that the quoted modules are capable of handling the change. The system is just asking you to check. For example, the proc_sys_reset_0 may need to be connected to a different "Slowest_Sync_Clock" if you change clock frequencies (this is a hint - connect your slowest frequency to this port!).
The crucial test is - can you successfully validate the clocks? If yes, you're "home free" :)
Howard
12-04-2012 11:09 PM
Use the Clock Generator IP in the XPS catalogue.
Howard
12-04-2012 11:19 PM
12-04-2012 11:50 PM
For Spartan 3 the clock generator instantiates a DCM to your specification. I don't understand the problem as you describe it. Why can't you use the IP?
Howard
12-05-2012 11:22 AM
Howard
Hi hgleamon1,
I read data sheet again. Yes, clock generator instantiates a DCM. But I can't find the wizard to use it. Could you tell me where to find it in ise 13.2?
Best,
12-05-2012 12:51 PM
You are using XPS aren't you (at least you stated that in your first post)?
Personally, I find it easier to configure the IP directly rather than use the wizard but you can access the wizard from the Hardware toolbar menu:
Like I said, if you read the IP datasheet so you know what parameters mean what, you can go ahead and configure it directly like any other IP.
Howard
12-05-2012 05:07 PM
Hi hgleamon1,
Thank you.
I have tried the clock wizard. When I enter the desired frequency 11.2896 MHz in the drop down menu, there is a message popped out saying the frequency can't be generated. That's why I use dcm to manually select parameters M and D to systhesize the desired frequency.
May I ask how could I do it with clock generator? Thanks.
Best,
12-06-2012 03:47 AM - edited 12-06-2012 03:48 AM
This is not the same frequency as you mentioned in message 3 of this thread. Which one do you actually want? Must it be so accurate?
What is your input frequency? Do you know that it is possible to generate your desired clock, with integer M and D?
I'll have to have a go myself and see what happens. Give me your input frequency and I'll play around a bit.
Howard
12-06-2012 11:31 AM
Thank you so much for helping.
I'm sorry foy the confusion. I tried to put different values int to the clock generator.
If I put the value11.00MHz into fsl_i2s_0, the warning says "The frequency <11.000MHz> you entered can not be generated using the current reference clock. Please enter diffferent value", which means M and D are not used, riight?
Since the desired frequency is 11.2896 MHz. It can't be generated from 50MHz clock. Therefore, I use the approximated value 50*M/D=50*7/31=11.2903225806MHz and put the value into fsl_i2s_0. After clicking OK, The warning window shows "Please make sure the core specific logic for the following components is in sync with the system changing: proc_sys_reset_0, fsl_i2s_0, dcm_module_0". Does it mean I succefully generate 50*M/D=50*7/31=11.2903225806MHz?
12-06-2012 11:35 AM
Forgot to say.
@bs0826 wrote:
Forgot to say.
Howard
12-06-2012 01:20 PM
After pressing Validate Clocks, it shows "validation was successful".
Thank you for detailed explanation. :)
