Question on post-build steps with Vitas IDE 19.2
I’ve created a DOS batch file that I execute after building my project (using the “post-build” step). When I execute the batch file from the DOS command window, everything works fine but when the IDE executes the batch file, there is a problem with the batch file reading/writing Windows Environment Variables. I tried searching the Xilinx website for “post-build” but I didn’t find anything.
Is there is any documentation for adding/running post-build steps?
Is there  special syntax I need to use to read/write Windows Environment Variables?
Everything else is working in the batch file, I can execute Perl scripts, execute DOS commands, create tar files, all within the batch file, I just can’t get Windows Environment Variables working.
Attached is my batch file.
