cerilet
Read double-precision data from SD card
I am using SDK to program a standalone application to run on the ARM. I am trying to read double-precision floating-point data written by Matlab in the SD card, process the data, and write it back to the SD card.
What I do first (on Matlab) is convert the double format (64-bit) to uint8 and write this data to a file located on the SD card with the command:
 fwrite(fid,typecast(data,'uint8'),'uint8');
Apparently, the data is written properly. The problem arises when I read this data using the f_read of the xilffs library. When it finds a 10 (which ASCII value corresponds to a new line), it skips this value and reads the next, corrupting all the data after that.
What can I do to overcome this problem? By the way, in Matlab occours the same problem when using fread.
Thanks!
cerilet
Ok, problem solved.
In Matlab I was opening the file to write the data using the 'wt' option:
fid = fopen('asdf.txt','wt');
When using the 'wt' option, the file is opened as a text file. I solved the problem by removing the 't' and like it is a binary file, I used another extension to save the file:
fid = fopen('data.dat','w');
Now I do not have problems when reading an ASCII _new line_ character.
Cheers!
cerilet
Ok, problem solved.
Cheers!
jianmingli1
@cerilet
Hey friend,
may I ask you a question about reading double from sd card? I see your idea is great.
After you convert the double data to uint8 and reading the data, how do you convert the data back to double in SDK?
I am trying to read double data from sd card and convert to u32, then do some processing.
And I was using am example .c file from Xilinx SDK installation folder (attached below). In the example, the data type for reading is u8. Do you know how should I modify it?
data i.e.:
-9.7656250000000000e-04
4.8828125000000000e-04
6.8359375000000000e-03
-2.9296875000000000e-03
Hi All,
 I am also facing same problem .Can  anyone help ?
sarath
