Visitor wave85
Read from file in SDK 2017.1
Hi, i need to read data from a file in a bare metal application. Since the file contains too much data, it crashes. Is there a way to do it?
Re: Read from file in SDK 2017.1
Are you using a file system (for example xilmfs)
https://github.com/Xilinx/embeddedsw/blob/master/lib/sw_services/xilmfs/src/xilmfs.h
You can enable this in the bsp, and config t his as needed. See ug1026 as this uses the mfs for the webserver.
Visitor wave85
Thank you im gonna take a look into it !! I must load a lot of weights for a convolutional net and when the layers are too big it crashes. Previously i've been using linux and it ran perfectly probably because there is a file system. Now i moved the application on bare metal and i've been having some issues. I'll let you know how it works.
Visitor wave85
Hi, i was taking a look to xilmfs. It seems i can create my own file system in DDR, create , open , write and read files in it. But can i copy files from my computer's file system to the new file system? I have some files containing "weights" which i need to transfer in DDR.
Yes, linux would be much easier here as there are utilities you could easily use. With BM you can use the available libraries such as the one I mentioned. Or create your own app using the available interfaces in your system.
With the mfs you would need to create the mfs file ( see xapp1026 for help here) that contains your files. Then use the xil_mfs api to read the file.
If you wanted to read directly from pc, you could use the use, uart or Ethernet for example and use the driver API. However, you would need to create the application here. I'm not aware of any applications here.
Visitor wave85
Thanks a lot , i will try creating the mfs file which contains my files and then use mfs apis to read it. Unfortunately i avoided using linux because in my application im using the DMAC PL330 and it gives me several problems on linux, while it perfectly works on bare metal. I will let you know in a few days , thank you.
Voyager
Voyager
@wave85
There is a way in SDK to load a file from your computer and put its contents in the device memory.
Under the "Xilinx" upper tab, select "Dump/Restore Data File"
Then fill the info in the pop-up window.
Visitor wave85
Thank you Ericv , i will test both methods tomorrow when i get back to the office.
Update: i tested the dump/restore memory feature and it does not work for my purpose. I am writing a file in a memory location but when i read from it , i always read the same number value despite from the file i load into it.
